Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
1990 3vze Code 51 Under Load
#2 (permalink) |
Personal
Sales Rating: (0)
Yup, that's what it says. http://www.ncttora.com/fsm/1993/engine/85diagnosi.pdf
IS your A/C on when the idle drops (not the switch, but the compressor itself)? If your A/C idle-up isn't hooked up correctly (seems to happen pretty often) that should cause a big idle drop.
__________________
1994 6cyl 4wd XCab -- all stock |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
It behaves as it should with the A/C on. Compressor clutch locks, rpms go up. Compressor clutch disengages, rpms go down.
The low idle behavior exists, generally, with the A/C on or off after the engine has been at operating temperature for 20 or so minutes and most often in stop and go traffic, or after several rapid, successive starts and shutdowns. Like going to the bank, grocery store and hardware store. The "running 51" goes when the A/C is on AND when throttle is opened. It goes away when both conditions are not present. EG, no throttle applied, no ac. I just checked the TPS, and everything seems to be in range. I installed and calibrated it myself in September. No hesitation or bucking. 16mpg in a 3.0 4Runner, occasionally getting up to 17 on summer gas w/o ac. I was getting 12-13 before I replaced the TPS and distributor. Advance is now set back to 10btdc. Interestingly, it just passed emissions with flying colors, except the idle CO, where it barely scraped by with 0.02 to spare. Low idle, rich state and too much advance generally cause that, I think. |
#4 (permalink) | ||
Personal
Sales Rating: (0)
Quote:
Quote:
__________________
We're sorry, theYOTATECH member you have reached is temporarily out of order or is no longer in service. Please feel free to ask our many other highly informed members about your problem. Or try using the search feature to find the appropriate information by yourself, and solve the issue on your own. Thank you for choosingYOTATECH. Good bye. I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 04-07-2012 at 01:43 PM. |
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks, MudHippy. That's how I understood it; but I wanted to make sure someone else came to the same conclusion. More eyes on the problem, and all that.
I set the ignition timing back to 10btdc, and replaced the o-ring on the idle adjust screw. The old one was hard and there was basically no resistance in turning the adjust screw. It was previously set to 12btdc. Could this advance have been the reason for the erratic low idle? My understanding is that the ECU adjusts advance as one of only means it has for controlling how the engine is running. So I warmed up the truck to full operating temperature, jumpered it and set the idle. I drove it for 15 miles at high speed, low speed and even simulated heavy traffic in my neighborhood. Every time, it returned to idle at 800. I wasn't able to test "off and on" conditions, but will tomorrow when I go run errands. I also did not test idle conditions after running the a/c and then shutting it off without turning off the truck. |
| Tags |
| 1990, 30, 3vze, 41, 4runner, 51, 89, ac, cel, code, codes, flashing, sensor, shift, stops, toyota, unplugged |
